I have two tires that have splits like this right on the tread of the tire. They are in a couple diff locations. I put a bolt on each side to show it. What would cause this and is it ok to run? They are 10.00-20 tubed tires. Would tthe cold weather cause this? --- Help
post-2596-0-54023200-1320358960_thumb.jp
https://www.bigmacktrucks.com/topic/21416-anyone-seen-this-happen-to-a-tire/
Looking at your pic, looks like it is caused by side scuffing or blunt impact, usually means the belt(s) split for want of a better word. Probbly the age of the tire added to it. Me, I'd look inside the casing and see if its split there to, if not I personally would run them but keep a close eye on them. Paul
They were new... 4 months ago so I cant say old tire. They are on the rear end.
What are you guys paying that are running the 10.00 tires for a new tire? Lug or Highway.
Just because you bought them 4 months ago doesn't mean they are new. If they sat in a warehouse for several years, they are still old. Check the DOT number for the date code to be sure.
Update, I found a guy with 4 virgin 90% tread lug tires I bought today pretty cheap. Guess il be mounting 4 tires now but it sure will look alot better with them too.
So , I will have two barely used 10.00 tires , highway tread with no cracks or weather checking if anyone needs them. Also a PTO set up off the Mack.
  • 4 weeks later...
If I am seeing it correctly you have cracks at the base of the grooves (groove cracking). This condition can be caused by high side forces applied to a rib type tire. Can also be caused by petroleum damage, weathering, or exhaust on drive tires. If cracks are greater than 2/32" contact the tire manufacturer. Can be caused by tight turns.
