Which type of air cleaner does your truck have?
If it's the top inlet oil bath type, it should be OK, as that's what the B613's etc. with turbo 673 engines were factory equipped with.
If it's the bottom inlet, then perhaps not, as I've never seen one of those on a truck originally equipped with a turbo engine.
https://www.bigmacktrucks.com/topic/2158-end673-change-to-237/#findComment-10590
Hi there Herb...ours is the wrong one I guess so have to figure something else out....
Also another question.....maybe you can tell me where to find out....
"How does Interaxle power divider work...also installed...a power divider lockout"
There must be some place to get this info!!!!lol :D
Thanks from the Saskatchewan dummy
Joyce
https://www.bigmacktrucks.com/topic/2158-end673-change-to-237/#findComment-10617
