Could be leaking past the pipe plugs in the water jackets of the cylinder head. I think it was around that time frame that they were having trouble with leaks from the plugs, so they started using an encapsulated epoxy on the plugs in the heads. Might be another oil cooler or leaks around the liner at the counterbore.
