I recently acquired a '52 LF which needs some cab work. The lower back of the cab is rotted out pretty bad, as are the lower door posts. Although I am new to Macks, the design of the lower cab rear leads me to believe this is a common problem. So, my questions: 1) does anyone make replacement cab backs for the LF, and 2) is the LF cab the same as any other models (from some pictures I have seen, it looks similar to the A model). Thanks in advance!! Corey
https://www.bigmacktrucks.com/topic/21843-l-model-cab-parts/
Thanks, Vinny. I'll check that out. Fortunately, with the relatively straight lines of the L model cab, it shouldn't be too hard for even an old farmer like me to fabricate replacement panels. Still wondering, though, if the L cab is the same as any other model....
https://www.bigmacktrucks.com/topic/21843-l-model-cab-parts/#findComment-92533
There was someone that was reproducing back panels and floor sills for the L cab,he used to advertise in Wheels of Time & Double clutch,been quite awhile back,but maybe someone has his contact info.
Thanks, Ron. Hope someone might have an old issue with that info....
https://www.bigmacktrucks.com/topic/21843-l-model-cab-parts/#findComment-92567
