It is actually the "spring" for the early Bostrom suspension seats. It is long obsolete and doubt you will be able to locate one. I have two seats like that and each has a broken rubber spring from deterioration.
https://www.bigmacktrucks.com/topic/21941-b-73-seat-parts/#findComment-93642
The rubber piece in question is the torsion part of a suspension system for the seat. I have a seat that was mounted on the passenger side of a 57 b61 that has the same setup. I have no idea where to get parts for it but will check the seat for any markings or part #'s and see what I can find.
https://www.bigmacktrucks.com/topic/21941-b-73-seat-parts/#findComment-93788
try the John Deere and Oliver rubber seat spring guys, The tractors from the late fifties used these rubber torsion springs and they are being reproduced. The ones from the tractor seats can be used with a little work.
15 gears...no waiting!
https://www.bigmacktrucks.com/topic/21941-b-73-seat-parts/#findComment-93802
