I have a B61 that I am restoring. It has a 711 with a turbo. I was wondering if anyone ever tried to put an air filter directly on the turbo. I have found one that is 10.5" x 10.5"" with a 4" intake. I found an adapter to make it fit my turbo that is 3.5". It is rated for 600 cfm. Is this big enough not to starve the engine? I am missing the air intake parts that go from the air filter into the cab. I also have a paper element type of air filter. It is 1" bigger in diameter than the stock filter, but the air outlet is 6". The only way I can figure to make this work would be to cut out part of the hood and put the air intake in that way.ny ideas would be appreciated.
Brian
https://www.bigmacktrucks.com/topic/22150-air-filter/
