Hi all, I've a 1988 R model w a 350 engine coupled to a 1070 trdl (says on decal in cab) transmission. I've been having problems both getting the truck into reverse and or high range. I've gotten stuck a few times trying to back in places. I found that if the air selector wasn't working that I could pump all of the air out of the truck by repeatedly pressing brakes and then when the pressure got back up to around 20 psi I would be able to get truck into reverse. I've changed the air filter constantly and even put an accessory air regulator on the shift handle which allows me to fine tune the pressure however, the truck still doesn't shift like I want it to. Has anyone had experience with this trans.? is the a air cylinder or something I need to replace Thanks in advance and Merry Christmas to all!
https://www.bigmacktrucks.com/topic/22302-1988-r686-wtrdl-1070-trtx-1070/
You need to rebuild the shift cylinders on the top cover of the transmission, and the selectair valve in the cab. They are leaking air from age. If you use PAI parts and supply the labor yourself, there will be less than $50.00 in the rebuild of both cylinders and the valve.
