Leave it to PACCAR to design the break away front end. The frames are weak in that series of truck at the spring hangers.
What really happened here-
"Robert" is driving along a deserted country road to avoid the scales on the big road, as he is grossing 90,000+ with a load of corn. He stops in the road to pee and when he tries to take off again he forgets to put the transmission in the low side and stalls the truck. When he tries to restart the truck the starter drive sticks so he has to shut it off again. The starter is burned up. So he calls his friend "Lawrence"...
"Hey Lawrence, can you bring your pickup over here and give me a pull start-I need to get going asap here!"
Lawrence says " sure thing Robert, i'll be right there".
Moments later Lawrence pulls up in his crusty, rusty, but trusty 4-wheel drive Dodge pickup with a 900hp blown hemi engine in it and a tow strap capable of pulling the Titanic off the bottom of the ocean.
He backs up to Robert and they connect the tow strap, leaving about 200 feet of slack in it so Lawrence gan get a good running start.
Robert says to him "just give me a second to release the brakes".
Lawrence thought he said "OK, floorboard it Lawrence".
The End
"Robert" is driving along a deserted country road to avoid the scales on the big road, as he is grossing 90,000+ with a load of corn. He stops in the road to pee and when he tries to take off again he forgets to put the transmission in the low side and stalls the truck. When he tries to restart the truck the starter drive sticks so he has to shut it off again. The starter is burned up. So he calls his friend Lawrence...
Moments later Lawrence pulls up in his crusty but trusty 4-wheel drive Dodge pickup with a 900hp blown hemi engine in it and a tow strap capable of pulling the Titanic off the bottom of the ocean.
The End
And the Dodge carried on with life as usual after ascertaining the readily visualized damage to the PACCAR produced excuse.
Yup,
The End.
I thought you were going to say he forgot to release the brakes hahahaha ,
Man you come up with good "true" stories! That made me laugh so damm hard!
yep, it's all true- came in on the ol' super secret spy satellite data download.
I will tell you this. I bet he about sucked the seat up when that happend. I've been pulled once and pulled a guy I don't think I have ever seen this. I need to dig out the pics when I was an operator and one of the Macks turned over and almost went in the drink
