The engine speed sensor is on in LH side of the engine flywheel bellhousing, goes in from the side. The engine position sensor is on the front timing cover. These 2 sensors get misidentified alot. Both are the same part number and will interchange with each other. The egine position sensor has to be agjusted with shims while the enine speed sensor does not.
OK thanks i well have a look at them the fan cuts in when i start the engine and turns off for a mint and then comes back on even when the engine is cold does the fan have any thing to do with the speed sensor
