With key off, unplug all 3 engine ECM connectors and check for oil of antifreeze in the harness connection. especially the top right one. This code is a low voltage code for the Behr electric engine fan. Check the engine fan connection plug and wires. Does the fan ever disengage?
No, it is always on. The plug is connected; but, the truck threw a belt a couple of months ago and disconnected the plug, which might of damaged it. I don't know how to verify if the fan clutch is working correctly; I do not have a wiring diagram, or a service manual. I will check the condition of the plugs on Monday for dirt and debris.
