Can anyone tell me how much boost pressure I should have on a 350 E6 . I checked with a hand held gauge against gauge in truck and both are reading 16 psi on a hard pull. I haven't had this truck too long and it just doesn't seem to pull like I heard it would . The vavle train was gone through and re-adjusted. That helped alot but still doesn't want to motivate. Any suggestions?
Edited by sdb89mack
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/
I had our local "Mack" man of 40 + years remove the barrels on the top of my pump, 1988 350 and remove the springs and "squish" plates. Using a piece of plate glass for a flat surface then with fine emery cloth over the plate glass wet with diesel. Holding the flat surface of the squish plate on the wet emery trace a figure 8 with your hand till any imperfections are removed. This was done to my 1988 350 and it helped performance 100%. Tim
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/#findComment-97215
Any idea as to why that would help?
Those little "squish" plates are actually the check valves in the delivery valves. If they don't seal as imperfections cause, a portion of the fuel contained within the plunger barrel awaiting next injection cycle is allowed to bleed back into the fuel gallery within the injection pump and return to tank. The plunger upon traveling up the bore of the barrel has to make up this lost volume of trapped fuel and replenish prior to the building pressure within the barrel overcoming the spring pressure of the fuel injector that allows injection. The long and short is too little fuel volume is injected. This is why the power is down, smoke is down, and turbo boost is lacking. \
Those check discs and the springs are renewed at rebuild time. I've seen far too many pumps rebuilt due to these valves being bad. Pisses me off that so many shops whosale replace everything in a pump instead of controlling the costs by replacing only what is defective.
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/#findComment-97219
Thanks for the break down Rob, I don't know anything about injection pumps but when our Mack man took the imperfections out the truck went like day and night and didn't need to replace any parts. It was great not having to take the pump off to get rebuilt.
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/#findComment-97225
Honest mechanic shops are few and far between. A good portion of mechanics are "box swappers" and in some cases need to be as subassemblies are no longer available.
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/#findComment-97232
Thanks guys for the input. Will tear into it this weekend and give that a shot. Much thanks again. Sam
Cleanliness. I can't stress that enough.
https://www.bigmacktrucks.com/topic/22544-1989-mack350-turbo/#findComment-97403
