B61 with Duplex, in dealer for service, they report a leaking output shaft on trans and a leaking seal on the rear. No quote to fix yet. I think the output shaft has leaked for years, and last mechanic advised to ignore it, fix cost too much for a 5000 mile a year truck. that make sense? Going to drive it Tucson to Co springs and hopefully up Pikes Peak- hot weather- should I spring for it?
https://www.bigmacktrucks.com/topic/2269-out-put-shaft-seal/
I would fix it now it's only gonna get worse, it's not a big job and the seals don't cost that much, if the dealer gives you a crazy price just do it your self, if you don't have a seal installation tool try to borrow one or buy one, if you do any work on you truck such as brakes you will be glad you bought it.
https://www.bigmacktrucks.com/topic/2269-out-put-shaft-seal/#findComment-11188
Make sure there is no slack in the rear brg. or yoke before you choose to not repair because if a brg. is going bad you could hurt trans and those parts are too hard to find. Glenn Akers
https://www.bigmacktrucks.com/topic/2269-out-put-shaft-seal/#findComment-11189
