I usually use a suitable ratchet strap slung under the bellhousing between the framerails. It is adjustable and you won't have a jack or stand taking up floorspace.
I assume that you are using a truck transmission jack to support the trans.?
Gregg
Take some 3" or 4" channel iron and make a bracket that goes under the pan and up both sides (like a U only with square corners). Make the legs long enough so it clears the boottom of the pan. Just use a bottle jack centered under it to raise the engine. Place it as far rearward as you can. If you have any older Macks with the ESI Plus pan make the legs longer so it will work on them also. Hope you can follow me. Steve
