I have some slack in the bushings on the stabilizer/sway bars on the rear axles. (Not sure if that is the correct name.) Nothing wrong with the bars just bushings are worn out. I am getting some chine walk and wobble/sway when bobtail and not so bad but some when hooked to the trailer.
Is there a way or place just to have them rebuilt? Prices for new bars just to replace the bushings are unreasonablly high for this struggling owner/op.
Any complications that I should be aware of if I attempt to change them myself?
Prolly be more expensive to rebush vs a whole new one.
Easy replacement. 4 bolts is all thats on mine.
Get in place, line up all bolts and tighten good. Done.
