Can any explain to me exhaust ramp, I have a 1996 E7 400 I ran the overhead and all is fine but at certain points in the duration the exhaust clearence goes to .110. I am used to Cummins and to the best of my knowledge this is not the case but I have talked to some Mack mechanics and they say mater of factly that this is exhaust ramp up but I get no good explanation as to why and if .110 is a normal clearance for the short duration time.
thanks, Frank.
https://www.bigmacktrucks.com/topic/23758-exhaust-ramp/
This is for the dnyotard engine brake.It drops the dynotard cyl down engough so it will fill with oil and then cam pushes it up and it will lift more than the cam raises in in normal operation and then it releaves the compression like a jake brake.
https://www.bigmacktrucks.com/topic/23758-exhaust-ramp/#findComment-106604
this engine has a jake brake system now should this cam be used with the jake brake system or should a different cam be used. Also thanks for the explanation, I have not been able to get anyone to explain it that well.
Leave it along cause it want hurt nothen. If its a E7 there is only one cam made any way.
https://www.bigmacktrucks.com/topic/23758-exhaust-ramp/#findComment-106918
