My R model is lacking in gears , 5 speed trans . I know Mack made multi speed rear ends . The rear end has side plates that remove , did the multi speed units just bolt on or like GM and Ford was it a different housing for a multi speed rear ?
Worse case i may need to find a 2 speed out of a LN800 Ford or something of that sort . Not much aroun here for Mack parts to find . If the multi speed was a bolt on then maybe i can find one and have it shipped .
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/
You would be better off changing the transmission and recalibrating the injection pump to "Thermodyne" settings.
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-109992
drove a number of 2 speed elec shift rears , other then a motor burning out now and then they werent an issue . Never used the Mack multi speed though . Thanks for the input .
Next question then , does the Mack use standard 10 spline clutch , in other words can i drop a 9 speed out of some other truck in there ? Would have to alter the drive shaft but thats not a big deal . This is a working truck and needs help . Not interested in repowering the truck . 9 speed would be smaller and lighter then the current trans .
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-110119
Most trucks use a 2" 10 spline input shaft. I've replaced several Mack five speeds with both Mack, and Fuller transmissions without replacing the clutch but strongly prefer to change it also when apart. It is a maintenance type thing and expensive to take a truck out of service a second time. This is especially true when the "well shit", why didn't I just do it right the first time factor is accounted for. The original clutch is prolly working very hard right now to start off heavy loads so will have considerable wear from the start of your changover.
I've never seen Mack built multi speed rears. Most I've been around are Eatons. I too prefer the air shifted as opposed to electric. If a guy opens up the air flow orifice they will shift very fast in either direction. The electric shifted axles I've been around are fine but become "finiky" after they age if they are used regularly.
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-110132
Thanks Rob , yes i would change the clutch while i had it down . Just had no idea if id find something standard or some odd " mack only " clutch set up . A 9 speed is smaller/lighter then the Mack trans . Man that thing is HUGE . I didnt know who made the multi speed rear under a Mack , i just new they had them .
I think a 9 speed would really help that little 237 Mack motor pull the large loads .
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-110501
I would go with a Mack nine speed myself.
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-110507
Rob's right, the Mack T2090- 9 speed would be a good trans, just make sure if it's pre 1990 you might want to check an see that it has the up-grade on the top shifting cover (heaver forks) My 89 Superliner had a 2090 and I broke one of the main shafts twice, when the shifting fork would break and put the trans. between 2 gears and BANG!! That truck had 4.64 rears-24.5 tires and would run about 80 mph. I did in fact get a ticket for 77 mph an that was when the speed was 55!!
BULLHUSK
https://www.bigmacktrucks.com/topic/24081-multi-speed-rearends/#findComment-110512
