model E7-350
Recently blown head gasket, and we are trying to troubleshoot why. I have the head removed, and i used to digital micrometer to measure the rise in the lifters. They are as follows:
Cylinder 4;
Ex - .4320 inch
In - .3220
Cylinder 5;
Ex - .4240
In - .3165
Cylinder 6;
Ex - .4340
In - .3205
The Cylinder 6 is the one which blew out. Do these look like exceptable numbers for the lifter stroke?
https://www.bigmacktrucks.com/topic/2412-checking-lifter-rise/
I assuming it is a Mack engine maybe an E6. Check the height of the liners. We had an engine a month ago with one(1) liner down and it caused the head gasket to blow. The lifters I believe have nothing to do with blowing head gaskets. I'll check and see what the height of liners need to be and report back as soon as I find that dimension. If the liners are down Mack makes shims to bring to back to specs.
https://www.bigmacktrucks.com/topic/2412-checking-lifter-rise/#findComment-11931
  • 1 month later...
