Looking for a water pump and tie rod ends for a 1947 en 510 fire truck! help!
Welcome to the site. I assume the engine is an ENF510A (2 spark plugs per cylinder), correct? If you still have the old water pump the best thing to do is to get it rebuilt. There are many places out there that will do it; I would ask around at a local truck repair shop about who is good in your area.
The best thing to do with the gaskets is to use silicone as a replacement or you can make them out of suitable gasket material.
Have you tried a truck parts supply house for the tie rod ends? If you have them off already take them with you to a parts house with the Mack PN and they may be able to match them. I assume you have already done an online search. If not, you may be surprised by what comes up if you start digging.
Good luck and post some pictures of your truck when you get a chance.
