I own a 1974 Mack CF685 fire engine and on the ceiling is a roof mounted vent. This is manually opened from inside the cab. Inside the cab is a plastic shroud/flange that interfaces with the vent and the headliner. Well, over the years, that plastic piece has been broken numerous times and could really use replacing. Anyone know where I could find one of those? How about a new headliner?
https://www.bigmacktrucks.com/topic/24580-mack-cf-ceiling-vent-help/
Lancaster County Upholstry in Lancaster, Pa. (717) 569-3281 may be able to help with the headliner. Someone on this site may have the other part. If you have not joined SPAAMFAA I would suggest joining. You can join a local chapter and also list the part you need on thier site along with a request in thier quarterly newsletter.
Mark
  • 1 month later...
