Does anyone know the difference, in the number of teeth (I presume), between the coarse spline and the fine spline apparently offered in the Mack rear ends?
In my search for a single axle 4.17 ratio rear end - this question has been very common, and I don't know which one I have or which I need.
Thanks,
Paul Van Scott
https://www.bigmacktrucks.com/topic/2478-driveshaft-question/
Thanks,
Paul Van Scott
Paul, the torque rating is substantially higher with the coarse splines. There is a lot more "meat" in the splines.
If you use a Thermodyne series engine, either spline size and type will work in your application. I would not use the fine, or smaller splines with a Maxidyne series engine as they will twist, and gaul, (over time and usage).
https://www.bigmacktrucks.com/topic/2478-driveshaft-question/#findComment-12207
Hi Paul,
I would suggest that either will work fine, I don't believe 200 hp will tear up too much.
If you are going for the junk yard differental I would make sure your u-joint match up
to the b-model transmission is the same, It will save alot of problems down the road.
I have been helping Garth Huff with this very same problem for a while, the fine spline
yoke seems to be hard to find. I haven't come across one yet. I am tring to talk the
Mrs. (soon to be anyway) in to going to mcungine, I hope to see you and your uncle there.
Fred
a.k.a. Morgan
15 gears...no waiting!
https://www.bigmacktrucks.com/topic/2478-driveshaft-question/#findComment-12208
Thanks Rob and Thanks Morgan,
I was pretty well resigned to having to manufacture a new driveshaft anyway - so the yoke difference wouldn't be so bad.
There are a few of these 4.17 rear ends around - and I think I found one in Minnesota that has a complete Mack air ride too. It does have the coarse spline, but at least it is a front loading unit rather than the top loading Mack rear end. My alterations should be minimal.
Hope to see you at Macungie! Keep your phone on Morgan - I'll call when I'm close to the show grounds on Friday afternoon.
Paul VS
https://www.bigmacktrucks.com/topic/2478-driveshaft-question/#findComment-12214
