:bmod1:
Hi all;
My EN 354 has a wierd cooling problem;driving in town,or going down the highway it runs between 180 and 210 degrees,which seems to be okay with it. but every time I pull it into overdrive,the temp goes right to 220.
I know the cooling system needs to be flushed and re-filled,but my question is regarding the thermostat. I pulled the housing while replacing the top hoses,with intention of replacing the thermostat,but it seems to be installed permanently. It looks to be connected to a pin that's pressed through the housing towards the top,and welded. I could be wrong,but thats how it looked to me. Rather than destroy it,I just cleaned it up and reassembled it.Would it be possible/recommended to remove it and install a modern type thermostat in the housing?
Thanks for your help.
Speed
:bmod2:
https://www.bigmacktrucks.com/topic/2483-en354-thermostat/
