Here we are moving the old girl off the big road for the weekend but I have to work.....maintenance....Good old Mack moving her.post-426-0-12099200-1336788566_thumb.jpgpost-426-0-67441300-1336788629_thumb.jpg
What is oversize with that load? Weight?
https://www.bigmacktrucks.com/topic/25059-off-for-the-weekend/#findComment-118794
Definatley weight, Probably height. Might be width if the trailer is wider then 8'6"
I figgered weight but I've seen a lot larger millers so wasn't certain.
https://www.bigmacktrucks.com/topic/25059-off-for-the-weekend/#findComment-118801
Are any of them a "He"? Or could that cause a scene when you put them side by side?
She weighs about 84,000 loaded with water and the drum is 7'3" and wide with the side plates and the belt housing she is over width.
Does "she" get offended if you haul her overweight ass on a "spread" axle trailer?
Always wondered.
https://www.bigmacktrucks.com/topic/25059-off-for-the-weekend/#findComment-119046
everything
It is perfectly clear now. DOT doesn't like the color so they make you placard it "Oversize".
I'm "down with it".
https://www.bigmacktrucks.com/topic/25059-off-for-the-weekend/#findComment-119062
Heres another oversize load,just for "uncle Rob"........................................Mark
I"m licking the seat first this time!!
https://www.bigmacktrucks.com/topic/25059-off-for-the-weekend/#findComment-119071
