Lipe Rollway clutch adjustment
The collar that the thro out brg is on is a threaded collar and it will screw in or out of the pressure plate. But there is a spanner lock nut on the collare next to the pressure plate you break aloose first.You dont have to hold clutch pedal down to adj. Set the clearance like a spicer of 1/2" and do this first.Then adjust the linkage next to get maybe 1/2" of brake on bottom. The free travel should then come out ok but its better to have some free travel than normal if the brake is ok. glenn
