i recently aquired a 1980 mack engine and tranny (6 speed 2 stick) and it has an air line coming from the intake manifold via the puffer valve. it also has 2 wires hooking on some object on the housing that operates hi-lo-reverse. what could these be for?
I had a 1980 Mack with 300+. I'm going to say the 2 wires are for the reverse lights circuit on the transmission.
As for the puffer valve air lines, mine was unhooked, did they not need the turbo manifold pressure to reach a certain psi before full fuel was given? I'm thinking that is what the purpose of the air line
