Well Uncle Rob, since the U model is offset it has alot of its weight on the left side you think right? Well I never thought that but heres something to prove you wrong,,,,,,AGAIN!!! Well since there is so much weight on the left side, what about the fuel tank on the other side? When empty or full.
looks like the fuel tank is on the right side in your picture. So that would act as a counter weight, as usual Rob is right. lol
Thats why there is extra room on the rt. side of those things. A large fuel tank on the outside, and a extemely large girlfriend for the inside. This is barely enough "counterbalance" weight to do the trick. You can now go through a rt. turn at 25MPH safely. Don't push the limit however as you would still be working against the physical laws of gravity in the northern hemisphere.
Uncle Rob
The fuel tanks are hooked together with a balance line. That keeps the amount the same in both tanks at all times. Yes, there are valves to be able to shut them off, but that is not normal operation.
"U" model dump trucks always use the rt. fuel tank for a hydraulic reservoir to keep from spilling over the left side when the truck rolls over. The driver can then use the "lightweight" kickstand option as it is much less troublesome to deploy for short periods of time such as coffee break.
It will gladly sit level on the flat going straight, but don't make any right turns in any kind of hurry.
Cousin Ben
Zactly.
Uncle Rob
Screw you guys, Im going home.
Dont go drivin' that lopsided rig too fast around corners because you're upset right now I would hate for you to flop it over! :tease:
Don't worry vinny we still love ya buddy.
Thank you Mike. Sometime Im going to have my Papa take a video of me driving at like 15 mph. Then you'll see. And dont say " Oh no, you cant do that, thats to slow" because its not.
Well Vinny I hate to be the bearer of bad news but that is sloooowwww. Those Mobility Scooters that the old folks use would probably pass you. Take care and use a higher gear buddy, see ya.
Your are correct again. That speed is certainly enough to cause that thing to roll on over when gradually turned to the right. Be certain to have the extra counterbalance weight installed, (or find a large girlfriend) before you do that drive. Don't want to come visit you in the hospital.
Uncle Rob
Saw this at the Mack Dealer today...
post-3242-0-81551200-1337201273_thumb.jp
I just called the local Mack dealer and they don't have them in yet but I reserved a dozen copies so I'll make certain Vinny gets a custom autographed one by his ole Uncle Rob.
I never knew MACK TRUCKS were MOTORCYCLES.
For an instant before they go over they balance on two sets of wheels; just like a motorcycle.
Uncle Rob
