Must be early production using the small cab, no dynatard, and the Farr air cleaner assembly.
Worth working with. Thanks for posting.
Uncle Rob
Uncle Rob
Rob why did the early to mid 70s V8s have the Farr air cleaner, did they flow more air than the donaldson. Ron
In my opinion yes, by far. Generator specifications called for Farr units when noise was not a concern. They were the worst as far as dampening the incoming air noise where Donaldson, and the other competitors excel. Farr brand had the largest filter media available and exposed to the air stream and used porous tubes to increase the filter area even more.
They fell out of favor as the engines were starting to become quieter in operation.
My RS795LST has one and it is just like a big sterio box (music to ears :notworthy::SMOKIE-LFT: ). As far as I now most of the 325s had farr air cleaners as a standard and the 375 had it as an option (donaldson was standard). I fully intend to keep mine on mty truck. There's my 2 cents :whistling: .
Thanks, Josh :bulldog3::SMOKIE-LFT:
Any pictures Josh?
Rob and Josh both of mine have 325s with the Farr, they sound like there sucking alot air when standing beside them, sounds like music to your ears for sure. Thanks Ron
If a water manometer is placed across a Farr box filter, and an equally sized Donaldson filter, it will still be found the Farr is a lot less restrictive. They are not much quieter in operation than an open intake with no filter however.
Yes but I suspect the truck was built in 72, and sold as a 73. They were allowed to deplete existing inventories in the production run on many things.
Seems like MACK changed the dash(and cab) mid year '73 model production.The early '73's were still steel,late '73's padded.That is a nice complete truck.I like the genuine MACK accessory door panels.
Vinny,
I'll get some pictures of it later today if I remember. It won't be to long before I'll have the old cab off and be ready to sandblast the frame up and paint it and install the new cab :banana::SMOKIE-LFT: .
Thanks, Josh :clock_logo::SMOKIE-LFT:
Vinny,
Your doing what im doing with the U model then arent you?
