When I spec my truck I would like to keep wheel base about 216"to 224".I would like to have twin 150gal fuel tanks and room for my ThermoKing APU.To do this I would need to have the SCR catalyst mounted behind cab, in vertical position like the Volvo's have on there day cabs.One dealer says this can be done and another says it can't be done.I need the rail space to hang apu.Any input on this?
https://www.bigmacktrucks.com/topic/25446-scr-catalyst-location/
You can spec it with a vertical stack. That's really the only way you will be able to get that short or a frame. The vertical stack is a big system. I'll try and get picks for you tomm.
If I can get the vertical stack like the New Volvo day cab has it will work.I may be able to use "D"tanks also.
