Now this is a serious question, no jokes. What makes a Detroit runaway? Is it the rack? Why dont they just pull the fuel shut off like in a normal truck? I was just thinking about that. Examples::::
http://www.youtube.com/watch?v=8M1o2rpO_JY&feature=related
One cause that I have heard and thankfully never seen is pulling the seals out of the blower and the engine will run on crankcase oil.
Don't know if true but sounds plausible.
On a 6-71 thats about 44 qts of oil or 11 gallons of potential run away FUN!!!
Oh, OK. I get it.
A diesels RPMs controlled by the amount of fuel being allowed into it. A worn engine, oil will blow past the piston rings and into the crankcase. The oil from the crankcase gets into the air intake from the breather. A diesel engine will run on this oil. The RPMs increase as the extra oil is taken in. As a result of increased RPMs, more oil is pulled out of the crankcase and into the engine. Now a cycle is created, more RPMs, means more oil, which means more RPMs. A diesel the normally run around 1800 RPM will run up 2 or 3 times that! The engine reaches a point where its now using its own oil as fuel, that shutting off the fuel won't stop it. It will rev up until it blows it self up. The extra oil can come from bad oil seals in a turbo, overfilling the crankcase with oil or even from the out side, like a power steering leak or even a propane or LP gas leak near by. Paul
Wow....I never thought I would understand that but I do. Thanks Paul!!! So my U model coul do that? :unsure::SMOKIE-LFT:
Any diesel can run away under the right conditions. From a Diesel VW car to a Mack. Paul
We had a detroit in a log skidder run off one time when a hydraulic line going to the front blade broke and it was routed next to the air intake.
That is why a detroit has the extra engine kill lever - it shuts a flap in the air intake so hopefully the engine will stop or at least not run off until you can get whatever is feeding the fuel to it shut down.
The first diesel engine ran on peanut oil if I remember correctly. We had a RD6 Caterpillar dozer one time that had been used stationary running a belt pulley for several years on waste asphalt oil - yuck! - it is interesting how diesels will run on any fuel if they have enough air coming in at the same time.
I always think that if engineers had been working on alternative fuels for the last 80 years instead of only working on diesel as a fuel, we would have been way ahead by now. The same with open pollinated seed corn - if we were to spend 80 years breeding better plants, we would not need hybrids now - I got off track a little there - sorry...............
Any diesel can run away, but a detroit is usually more common only due to the blower, worn seals or stuck rack. Most all leaky ol detriots have an emergency shut off(a control cable hooked to a flapper in the intake tubing) that is used to help shut them down from such an ordeal. Once you shut the air off, they will die away even with all the oil. It takes both to run air and fuel to run. Later versions had a solenoid controlling it from the key. Turn the key off, it closes the flapper automatically.
Geeesh! This bunch is going SOFT!
We actually answered Vin's question in a serious intelligent manner.....just like he wanted.
WTH????
This place is going down......
We were supposed to say that Detroits run away because they are SCARED!
Those videos raise another question.
Why do people run away from Detroits?
WTH????
O.K. here is the answer you expected...Diesels run away for these reasons. 1)Bad home life 2) to much stress at work 3)a bad marriage 4) No marriage, 5) owe too much money 6)did a bad thing and are afraid of being punished 7)just plain nuts 8) afraid of U models.
Better Answer???
The REAL Jumper here. Ben and I had a Scania run away on us when we first lit the B model up. Fortunately, Ben is a you-tube addict and had seen those other videos and we were prepared for it (a piece of tile to cover the intake). We recently got a 4-71 from a motor grader with 250 hours on it because it was junked for running away. Upon removal of the valve cover, it was determined that the cotter key vanished from the governor rod at the rack. I paid 20 cents a pound for the engine because of a 5 cent pin! Life is good.
Detroits are more prone to run away because of the pump-less injectors sticking from sitting, as well as the 2 stroke design with the air intake at the bottom of the cylinder sleeves dang near in the oil pan.
Vinny, nice meeting you at the show. Wasn't a U model something that the Germans had during the second world war? Does yours have a periscope?
post-10909-0-78145100-1332278883_thumb.j
I remember Ben telling me the B60 had a stuck rack.
It was very nice meeting you too Mr. Jumper. But no, the Germans had a U-Boat submarine, not a U model.
Ha, Ha, Ha! ROTFLOL!! That's funny, Dad.
But really, The way they're set up, when a Detroit isn't running, the injectors settle at full throttle. This helps make them very easy to start. Until the flyweights on the governor move out and pull the rack closed, the injectors stay at full throttle. When they sit for a while, the injectors tend to get stuck at full throttle and therefore, the engine runs away. When it's stuck at full throttle, it can start to suck its own oil and in turn, revving even higher. That's why they blow up.
Cousin Ben
Cousin Ben
I get it. Thanks Cousin.
