we are replacing the engine/trans in our '85 R model and cannot find the proper clutch relese lever to go inside the transmission.
installing an Eaton 15 speed, and has the clutch housing with the above and below input shaft hole for clutch release lever to be installed. The problem is that when the release lever (fork) is installed in lower hole of housing the fork will not reach the release bearing.
any one know what part # to look for or where one can be found? the transmission was out of a freightliner, and the lever was in top bore of clutch housing
any info. would be greatly appreciated, thanks in advance
https://www.bigmacktrucks.com/topic/25792-clutch-release-fork/
