Low coolant sensor fault, with the FMI of 3 its probably not low of coolant but looks mor like a electrical/ wiring issue or a bad sensor. Unplug the sensor and put a paper clip jumping the two wires together and see if the light goes out, hopefully it does , if not unplug both engine ECM connections and check for oil or antifreeze in the engine ECM and harness.
https://www.bigmacktrucks.com/topic/25839-trouble-codes/#findComment-125806
