what is the proper procedure to check for play in a center bearing? how much play is allowed?
could a bad center bearing cause a wobble/shimmy. my problem is at 35-40 mph. then wobble goes away.
any tips on replacing it. does not look like to big of a job.
thanks happy summer!!
https://www.bigmacktrucks.com/topic/25887-center-support-bearing-question/
My test for the center bearing was to grab the driveshaft and see if I could shake it. Or put my foot on the driveshaft to check for movement.
The ones I have are mounted in rubber. I figured that if I could get movement in the rubber by hand or foot than the torque of the spinning driveshaft could do the same.
It is not a big deal to change. The shafts are a liitle heavy so having a helper or a couple of floor jacks will help.
Chasing wobble, bounce or vibration is a bitch!
The movement should be almost nothing in my opinion.
Had one that doing the "foot' test moved the driveshaft about an inch.
Time for a new one. The rubber was just getting tired. The driveshaft on the truck in and out of the bearing were almost 5.5 feet long. I think it was starting a little whipping action.
thanks guys. i am gonna check it this weekend.
checked out the center bearing today. i laid down underneath the driveshaft and pushed up on the shaft. the rubber squished about a 1/4 inch maybe a little less. does this mean its bad or just weak rubber? i was told they all move in the rubber just as long as the bearing is tight your good.
