I'm trying to find out how the radiator mounts on the above models or the high end Cummins or Cat equipped models.
The 6 cylinder Maxidyne trucks have a shorter radiator which sits across a w shaped crossmember with a pipe coming directly out of the underside of the bottom tank.
The high HP models have a much taller radiator and the bottom tank sits much lower so there is no space for a crossmember below it. I can only guess that it either mounts to a crossmember that sits behind it or that the radiator side frames attach directly to mounts on the frame rails.
I'd be gratefiul if anyone can help me out here as there aren't any of these trucks over here in the UK so I can't get a look at one!
It's for a model project. I'm building an RS700L and I want to put an 866 into it.
Many thanks,
Alastair
https://www.bigmacktrucks.com/topic/25902-rsrl797l-771l-radiator/
