Number 1. Electrical issues are a BITCH!
Number 2. Electrical issues are a BITCH!
Number 3. Intermittent electrical....anyways, you get the point.
Start by checking ALL of the connections between the batteries and chassis/engine. Loose connections, corrosion at ANY connections, chaffing wire, pinched wire, etc.
Proper grounding is ESSENTIAL! Repeat ESSENTIAL!
Continue by looking at the harnesses that go into the cab .
How much added electrical equipment has been added to the interior?
It could be simple like a beginning to be faulty ignition switch or relay or ground.
Best I can say at the moment, Jim
First look to all the grounds for loose, dirty or broken. Paul
