Grant is correct. Remove the lock cylinder from the door and vent window assembly. Then remove all the retaining screws around the perimeter. With the window rolled down, the panel should drop in the opening of the door shell. You will have to manipulate the complete assembly to find the point where it literally just slides out. All the mechanism is readily exposed with the panel on a bench.
