looking over some pictures on here and elsewhere,and i know our primary interest is Macks (mine included) i just wondered what everyones favorite non-Mack truck is,and why?.......and not limited to modern,new late model etc. can be any truck past or present just curious to see what turns up!.............................Mark
https://www.bigmacktrucks.com/topic/26016-whats-your-favorite-non-mack/
big trucks-379 pete,(Im so ashamed),,,little trucks-old dodge power wagons,,,even littler trucks-tonka,,,even littler littler trucks-Hot Wheels,,,Now There, I said it! My first pick is Mack though. Maybe its just me, I havent found anything to compete with R model dump trucks, most specially offroad work. Both mine are kinda slow on highway, but you can just load the doodoo out of them and they will move it out, no jerking, no jumping, just take off. Dern, I likes em! randyp
mine would be a 1974 Hayes HDX 1000.Powered by a 525 Cummins KTA,6061 Allisson power shift,Clark BD 91000 rears@ 13.298 to 1.1400x25 Michilin H block tube less tires.Drove it for 27 years.Average 120 tons per load twice a day.
Theres a BRUTE still running around here with a roll-off setup on it,seen it 2-3 times now...............................Mark
Green with red frame?
Drove one for a while with the garbage co. up north
350 Cummins, 10 spd. Run good
I've driven about everything but a Brockway, Autocar, and Volvo. But just going by looks, the highbinder IH just looks bad-ass!
That's nocluejoe looking at this one.
This is the favorite of trucks i've driven.
mine would probably be Autocar then Brockway
And a Sight Liner too.
Ford. I've got a pair of Ford Rangers and an F250, along with an old 8N tractor. The first semi tractor I went to look at when I had made up my mind to buy one was a '97 LTL9000. I really liked the truck, but the one I looked at wasn't exactly ready to put to work...and I couldn't afford truck payments on a company driver wages while I figured out why NONE of the dash switches (or anything else electrical) worked. Sure, there were a lot of unplugged connections behind the dash...might have been as simple as plugging everything back in....but WHY had somebody unplugged everything? I walked away from that one & ended up with my '01 CH613.
My favorite non-Mack is the truck of my country's origin - YaAZ.
Production years were 1951-1958.
It's structure based on 40's Mack NR series although with a lot of differences.
Most chassis including front axle and Camelback are too close to Mack but reworked to metric.
The engine was two stroke, a copy of 6-71.
There were 5 speed gearbox and 2 speed transfer case.
Two parallel propeller shafts came to axles with no interaxle diff.
Cab has wooden structure with wooded outside lining on early series.
Nearly 20,000 units were produced.
The only one survived is known at the moment. Keeped in a closed army area with no chances to get it off.
Vlad
Wow, thats pretty cool they were almost a Mack.
