Lemme see ifn I can properly esplain this broke part on my 87-R. On the right front axle, on the spring, at the rear of the spring, there is a shackle that comes down and a pin goes through it and eye in spring. That pin broke, and spring just rides up against top spring hanger now. There are bolts on it, I guess to keep it from slipping? Truck is dropped bout 4 inches on right side now, got that tired look to it. My querstion is, is it safe or okay to jack right front frame up there, a lil behind shackle, to allow spring to come on back down, so I can put a new pin in it? There are grease fittings on top and bottom on pins in that location. Thanks fellow Mack afficianodos. randyp
https://www.bigmacktrucks.com/topic/26165-i-bwoke-it/
If the hanger has not broken, you can probably put a new pin into it. To be safe, I'd pull the spring out and get a look as the bushings are probably beat out and need replaced also in the spring eye. Lack of grease is the culprit here till fatigue finally caused the breakage.
https://www.bigmacktrucks.com/topic/26165-i-bwoke-it/#findComment-128216
Thanks all, And I have no doubt the Vinster is the cause of all this. Dern truck is sitting there like a silly ass u-model now. Maybe he will loan me his kick stand. randyp
Must be one of them silly assed "U" models admiring itself in the mirror cause those things don't roll over on the right; only to the left.
Kickstand is unneeded in the dillema/application you are experiencing.
https://www.bigmacktrucks.com/topic/26165-i-bwoke-it/#findComment-128259
Just break the one on the other side....then it'll be even again & you'll get respect driving through the hood in your low-rider. :loldude:
This forum is great....Where else could you get outstanding repair advice, and for FREE to boot!!!!!!!
https://www.bigmacktrucks.com/topic/26165-i-bwoke-it/#findComment-128331
