I've been waiting for my pemits from the town of Riverhead to remove some little trees to recover a WWII era combine. The powers that be told me it would be 3 to 6 weeks. Went down to find out my permit status since all I got on the phone was a machine. Well the employee who handles all the permits was laid off due to budget cuts.
My question was "what do I do now?"
Riverhead told be they have no idea...but you need permits to cut the trees to remove the Combine but they laid off the permit guy...so if you do it with out permits, Code Enforcement will ticket you for no permits at $500 per tree...so you need permits.
Well who will issue them now?....Town airhead replies "I don't know, the permit guy was laid off."
All for this!
https://www.bigmacktrucks.com/topic/26589-small-town-blues/
As a Code Enforcement Official myself, I would contact the Town Manager and/or one or all of the elected officials- they are the ones who caused the problem (the lay-off) and should be held accountable for the lack of action since they laid the permit guy off.
Also, I would ask to see a copy of the ordinance- I have never heard of needing a permit to cut down a tree, not to say it doesnt exist, but town officials have been known to make up a law or two from time to time.
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131798
I agree, I dont think they could enforce that so called ordinance. Tell them you are cleaning up the landscape by removing combine. Is it on city property or private property? Yeah, just cut the dern things, tell them to mind their own bidness,,,randyp
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131804
Go down to local nursery. Buy a handful of tree seedlings. If they show up and bitch just point to your truck and say you're going to put NEW ones back up. LOL!!!
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131807
What country is this??? You need a permit to cut down a tree to remove scrap to clean up an eye soar on the side of the road, I know that the combine is not any eye soar to you but to the city folks I am sure thats what they are complaining about.
$500 fine per tree, is it a fine or a tax??? from an over zelous town government
Robert
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131836
Town of Riverhead Department of Forestry
Tree Removal Policy
JAMES M. DUNNE, P.E.
Commissioner of Forestry 631-819 0043
TOWN CODE
Town Code Chapter 225 trees, requires a permit for tree removal on private property.
Tree removal means, “Any act which will cause a tree to be removed or to die within a
one (1) year period.”
REQUIREMENTS
A permit is required for the removal of any tree with the diameter or caliper of three
inches (3”) or more, when a tree is measured at the point four and one-half (4-1/2) feet
above ground level (DBH) at the base of the uphill side of the tree.
STEPS TO OBTAIN A PERMIT
1. Submit completed copy of the application no less than ten (10) work days prior to
the proposed tree removal date.
2. Complete all information required on the form including signatures from the
applicant.
3. A fully completed property survey form (enclosed) is required for an onsite
inspection.
4. For all applications requiring Forestry Department approval, there is an application
fee in the amount of five dollars ($5.00) per inch of cumulative DBH for each
proposed tree removal, but not more than seventy five dollars ($75.00) per
individual tree and not less than a total of fifty dollars ($50.00) per application.
5. In the case of an application involving the removal of two (2) or fewer trees, the
application fee may be waived or reduced at the discretion of the Commissioner
of the Forestry Department if the applicant should choose to provide a replacement
tree(s). In order to be eligible for credit, a replacement tree must be a minimum of
2 1/2 inches in caliber.
6. Once a tree(s) is removed a final inspection will be necessary to ascertain the
removal was completed according to the Town guidelines.
7. After the final inspection, a Certificate of Compliance will be issued effectively
closing the permit process.
FINES
Any person, who shall violate any of the provisions of this code, shall be deemed guilty
of an offence and, upon conviction thereof, shall be fined not less than five hundred
dollars ($500) but not more than one thousand dollars ($1000) per tree.
TOWN OF RIVERHEAD
DEPARTMENT OF FORESTRY
977 MAIN Rd.
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131858
New York.
'Round here, I just wrap a chain around the unwanted growths and give a little tug w/ the F250. Got a big'ol pile of 'em in the front yard awaiting enough rain so that I can burn it without also taking out the house & the farmer's field...
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131860
Got a yuppie winery across from it that films me every time I go near it. Stopped wearing suspenders to add spice to the videography. They demand it's removal and call the code enforcement and Riverhead P.D. every time I go near it with out permits posted on it.
I cut a sappling to open the hatch to look at the Chrysler flathead and in 5 minutes had the Code officer there.
Less than a mile or so away I pulled 11 crawler cranes over to cut the booms and houses up, not a peep said about it. Just a single check by code officers to make sure I had a pollution dam of bales and fire extingushers'
This is the new area for that crap. Come out from the city, pave and light up the house like an airport. Complain about the dust from the fields, chemicals, the water for irrigation, noise and smells from animals til they put you out of business. Than bitch about the loss of a scrub oak and sugar maple weed trees cause it "takes away the country look" they came here for.
Thats why the Cat in my avitar is my mail box holder and my cousin has a 50 Ford F3 flat bed made into a fountain.They have their wagon wheel and I've got my crawler. Paul
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131891
Hey Paul............have you ever decided to move from that Political Village? In Tennessee, the (TVA) or Tennessee Valley Authority has now after many years decided to clean up there right of way, under there towers, with a 75 ft. from center of each tower. They said if you have built, planted or anything else they will confiscate or clean out and cut anything in their way. I was one of those people that moved because I could not have anything in my back yard, because of their right of way.
I also hate the governments right to take your property if they decide to. Calling it Intimate Domain.
mike
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131908
mike
We got 200 acres and out buildings off Rte 15 in Fork Union Va. A good friend next door into guns,dogs and fire wood and Virginia Military school up the road. Hope to move back down in 2 or 3 years. Paul
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131913
I love the VMI in Lexington, VA . Old Jack sure lived for a short time in a beautiful area. I've been there and done that a bunch of times there.
Hope you can soon.
mike
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131917
Ok, it appears to be a legitimate ordinance.
Therefore, one thing I WOULD NOT DO (despite everyone's encouragement) is to go in there without the permit and "just do it." You are already on their radar, and the hippies across the street filming you dont help.
I pulled up the town's website- have you tried to contact the Supervisor yet? I would begin with him.
Oh and by the way this is the first time I have ever heard of a bullshit ordinance like this......
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131942
Hope you can soon.
mike
Not VMI in Lex, VMA in Fork Unionington it's a military boarding school from grade 1 to 12.
FWD, I contacted the Town Supervisor, The Head of the Highway dept and the Head of Code Enforcement, I'll most likly be getting a waiver from both to do the removal and the Highway dept will remove the trees on the road side. I do my jobs legally to the letter or not at all. Paul
The "tree ordinances" are in most Long Island towns, this is actually one of the more liberal ones too.
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131962
typical city hall bullshit i paid an overdue california tax bill $2000 bucks,,,just to clear it off my records,,,and they told me pretty much same thing,,,they keep people around to keep sending me bills,,,but nobody around to take it off my credit report,,,paid bill 7 years ago,,,and its still on there wow (WHAT A COUNTRY).lol.bob
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-131965
Damn...all this adherence to the law & compliance with regulations is making me sick. If Americans were as compliant in 1775 as they are today, we'd still be flying the union jack....
Seriously, what ever happened to property rights? Individual liberty?
Government agents are never welcome on my property....and when they DO show up, I try to make them as uncomfortable as possible for as long as it takes for them to leave the premises.
https://www.bigmacktrucks.com/topic/26589-small-town-blues/#findComment-132015
