I have a problem with engine shut down or know start. Engine will crank but won't fire.Ran a hot wire to solenoid in fuse compartment and truck will start. Check white wire from key switch to solenoid and it has 12.86 volts when off of solenoid but when i put wire back on solenoid it has only 7.43 volts. any help would be appreciated. Skipperchipper
https://www.bigmacktrucks.com/topic/26706-1993-mack-engine-shut-down/
