just wanting to know if my mr688s should have one or two wedges? i believe the original owner replaced the pass side front spring and may have not replaced the spring wedge on that side. either forgot or never realized there may be a wedge. unfortunately the original owner is deceased.
the driver side has a wedge, but not on the pass side.
my question is can i take a measurement anywhere to see if there should be one on the other side.
thanks gang.
https://www.bigmacktrucks.com/topic/26860-front-spring-wedges/
To get the measurements you need a caster / camber gage .
https://www.bigmacktrucks.com/topic/26860-front-spring-wedges/#findComment-134214
