thought i did but when i went to pull the pump i had to turn the pump to get it passed the gear . does the top dead center mark need to be on the motor pointer or the pump pointer when i reinstall the pump. i now i will have to pull the valve cover to bring up compression stroke now. just need to know what pointer to set at. Thanks
https://www.bigmacktrucks.com/topic/26942-1990-e7-400/#findComment-134685
