Hi, can anyone help me out with the adjustment on the clutch. This one has a locking tab with a bolt in it. I know how to adjust the ones with the bolt you push in while someone has there foot on the clutch and you push the bolt in with a 5/8 spanner. This is all the the pressure plate to adjust for wear.
This one with the locking tab is the first I have seen and have no idea how to adjust it. It's in a "73" R700. All help would be appreciated.
https://www.bigmacktrucks.com/topic/27418-clutch-adjustment-in-an-r700/
The adjustment is pretty much the same, remove the lock plate, hold the pedal down and turn the "lugs" on the adjuster ring clockwise to increase freeplay.
There is a tool for adjusting that style. http://www.amazon.com/OTC-7028-Clutch-Adjusting-Wrench/dp/B0002SREQS
