The flywheel is not balanced to the crank on either engine.I think the E7 will work on the E6. I have both engines and they take same rear seal so the dia is same on the rear journal. The E7 has a dowel on the crank just to time the flywheel for the timing marks.The bolt pattern is same and the E6 has timing marks on the front. glenn
https://www.bigmacktrucks.com/topic/27784-em6/#findComment-141421
