Oil temps seem to run alttle warm in the MP8's ( compared to the older Mack engines) which is normal. The coolant temp should be around 190(F) with 210 in a hard pull in the summer heat. We replaced alot of water/coolant pumps and fan clutches on these engines. We replaced 2 Cool Logic electronic fan clutches on the same 2012 CHU 505 in 3 months. Water pumps seem to fail around 200 -300 thousand miles.
https://www.bigmacktrucks.com/topic/27790-mp8-500hp-temps/#findComment-141762
