You need a set of shims to fix up a point of contact.
Set pinion and a gear in sertain position, apply some paint on teeth, load driven gear and turn.
Then look for a painted trace.
You need the trace at the center of driven teeth, make it up moving gears by putting shims.
If a gear set isn't wored out too much you have good chances with 5-6 steps.
