...between a 1954 GMC and a 1955 1st Series GMC because I'm starting to suspect that my pickup truck is a '55 1st series rather than a '54 like I thought it was but I don't know for sure. So does anyone know how to tell? Maybe the serial number or something like that? Because if it is a '55 then it's really rare and I don't wanna go customizing it.
I do know that it's a 1 ton, deluxe cab, long bed, with a 248 six cylinder, and hydramatic transmission.
What makes me think that it's a '55 is that my buddy has a '54 one ton just like it and it has a different dashboard, and my dash is different from any other '47-'54 GMC that I've ever seen. But I dunno. So if anyone can help me out with this, that'd be great :twothumbsup:
Ben
post-10909-0-78145100-1332278883_thumb.j
On the trim tag there should be a build date with a letter and a number. Or if you can get a picture of the tag I can check it out for you. It should be mounted under the hood.
~ JT Burkard ~
AKA Sweaty Mack
Okay, thanks. I'll be going to the shop tomorrow and I'll see if I can get a picture of it.
Ben
:SMOKIE-RT:
OldGMCTrucks.com has a number cruncher that'll tell you all about your GMC from the ID #.
Speed
:SMOKIE-LFT:
The doors are the same. The hoods interchange but have different emblems in different locations. The front bumper is the same. The running boards and cab filler panels are the same. The back and corner glass is the same. The seat is the same. Just about EVERYTHING else is different.
Cab: 1 piece curved windshield glass slightly different arc than 54, cab roof peak smoothed out some.
Completely different dash, different gauges, different knobs
Frame: different kick up in the rear, lower and flatter for the bed. Change to bell housing cross member to accomodate hydramatic trans which debuted in '54.
Bed: 2" deeper, flat tops, ribbed sides by the fenders, tailgate and tail lights change. It is more of a second series bed.
Front fenders: Recesses for marker lights, shorter front "overhang" where it meets the bumper.
Front grill: completely different
Front apron: shaped to match different grill
Open driveline:(drive shaft) 55 on series 1, 54 is a torque tube
235 / 248 /261 6 cylinders from 54 up with Hydramatic have a 60 psi oil pressure gauge
Most of this is from a 1955 G.M. Tech Bulletin. Dash and open drive shaft are the 2 biggest noticeable differences. Paul
Well it must be a '55 then because it does have the open driveshaft and the wierd dashboard. Thanks a lot for looking that up for me, I really appreciate it :D
Ben
Ben
I gathered that info a while ago in my search for a 3100 series 1955 series one to be the mate to my 1970 series one Camaro ( still a 69 body style titled as a 70) Glad it helped ya :banana:
Oh cool, did you ever find one?
Ben
Where are the pictures??????????????? :banana:
Well the plan now is to sell it so I can buy a '55-57 second series. My truck currenty runs and drives but it needs a master cylinder to stop so once I put a master cylinder on it, I'll post a for sale add on here and y'all can see the pics :twothumbsup:
Ben
Ben
I may have now :whistling:
How much are you looking for??
Well I may be crazy, but once it's running, driving, stopping and steering, I was thinking somewhere in the $1900 area. It's only got like 34,000 miles on it and everything works and stuff, it's just kinda rusty.
Ben
I'll look around and see whats here on both parts. Paul
That's good,I need to see what is still around here on the farms.
