Hi i have a 96 ch700-713 dump truck that i bought from a widow was a one owner etc.. It was set up for air brakes and a semi plugh in back . I switched it to the 6 pin round plug also put in the brake controller.. My problem is we have tried EVERYTHING i have singles 4 ways and marker lights . And even the brake controlers works perfect .. the problem is we can not get brake lights on the trailer !! The trailer i 1 yr old econoline trailer and it has a 5 wires the truck has 6going to it.. Does anyone have an idea what the heck i am doing wrong? Is there a brake switch we should be hooking into on the truck? Thats what i think is wrong ? Any help would be great thanks jerel
https://www.bigmacktrucks.com/topic/28154-no-brake-lights-to-trailer/
The trailer sounds like.it is set up for being towed behind a pickup or lighter duty truck that has the turn signals and brake lights on the same circuits. I'll have to look how I set mine up to overcome that problem. Give me a couple of days.
The trailer has 5 wires...what are they? Most likely:
Ground
Tail
Left turn/brake
Right turn/brake
Electric brakes
The truck has 6 wires...typically those are going to be:
Ground
Tail
Left turn/brake
Right turn/brake
Electric brakes
Aux. power
A 7-round "RV" style plug would have
Ground
Tail
Left turn/brake
Right turn/brake
Electric brakes
Aux. power
Reverse
Now on a commercial vehicle, the 7 round plug has:
Ground
Left Turn
Right Turn
Tail
Marker
Brake
ABS
If you want you turn signals to operate the brake lights, your best option is to tap into the rear tractor light circuit to get the power to your 6-round plug for the turn signals, since the tail lights on the tractor operate in the same dual-function manner (turn/brake lights).
Did you connect the brake controller "brake wire" to your vehicle brake light circuit?
That isn't a very good idea, since the brake controller is supposed to translate brake pressure into an electrical signal which tells the brakes how hard they need to apply. If you wire the brake lights into that same circuit, the brightness of the brake lights will vary...the harder you apply the brakes, the brighter the lights will be. It would be better to tap into the proper circuit in the truck to control the turn/brake lights.
I remember connecting a wire to the brake switch at the pedal. But this was a pickup not a semi.
Ken
