I power washed the crud off the transmission and it says TRTL-72. Now what does 72 mean? I see that if it was a
720 it would denote an overdrive gearbox. is it a 13 speed in the sense that you dont split 5th correct?
just 4th hi and strait to 5th.
-Thad
https://www.bigmacktrucks.com/topic/2827-need-some-tranny-info/
TR = Transmission
T = Triplex
L = Lightweight version. (Aluminum top covers)
72 means it is direct in 5th. (hi split in the compound is overdrive)
This is known as a single overdrive triplex.
It is a 15 speed. (can also be split shifted in 5th just like in the rest of the gears.
I believe this is the same as the transmission in Larry "Freighttrain's" B61.
https://www.bigmacktrucks.com/topic/2827-need-some-tranny-info/#findComment-13775
