Hello, I have a 2002 Mack cx613 , e-7 with a fuller semi automatic transmission & it's staying stuck on gear when I shift from reverse to neutral & then second, then I have to put it in neutral then reverse then neutral & it goes to neutral after a couple of attends, and when it shifts from 6 to 7 my reverse light flash 1 time quik in da dashboard, sometimes it dowshifts from 3rd to 2nd even if im accelerating. does any body have any idea on what da issue may b or what can b wrong? Dealer replace cluth 4 months ago & still da same. Also can i modify it to be stick instead of semi automatic & what parts will I need to change. Any help will b greatly appreciated. Thanks.
https://www.bigmacktrucks.com/topic/28366-2002-eaton-fuller-semi-automatic-issues/
