I have a friend with an 87 R686 with a 2 valve 300 and a 2 stick six speed I swapped in it out of an '82 model. He bought the truck from me a couple of years ago and hasn't had any trouble until recently. The compound stick is jumping out of direct, but it isn't making any unusual noise. He's convinced the transmission has got to go, but I'm leaning towards it being something simple. Could the problem possibly be in the plunger on top that works the compound shifter?
Jake
https://www.bigmacktrucks.com/topic/28561-two-stick-six-speed-jumping-out-of-gear/
Check the bolts again. Is there any gear oil leaking at the input shaft. You may have bearing and/or shaft damage from running with the loose bolts.
Sure will.. I haven't been under the truck lately but I'll definitely check it out. Thank you sir.
Jake
