I looked into the company for the flatbed we had a work. Seems like the have a very good reputation. Kinda pricey but then again you get what you pay for.
Tom I thought your step deck had ramps?
~ JT Burkard ~
AKA Sweaty Mack
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150400
Drop deck that i have doesnt have rear loading ramps. Just air operated ramps to get above the 5th wheel. Yes I've looked on Discount ramps and i do not have an extra 4000 dollars lying around.
was hoping someone had a used set they aren't using i could buy.
Tom
"Nothing Breaks Wind Like A Bulldog"
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150411
Discount ramps used to make some for another company to sell under their name and they marked them up about 20% but they were identical, they have the best prices I have seen anywhere and they make a quality product just make sure you get enough ramp dont buy a 5000lb ramp for a 10000lb job aluminum doesnt bend like steel it just breaks especially in winter.
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150414
Tom
$2300 for the 20,000lb ramp kit. The 10,000lb kit is $2,050 so for the couple extra bucks it makes more sense to get the higher rated ramp system. Plus once you buy it, its yours. If you get a newer trailer down the road, you take these with you.
You can probably talk to a metal shop who can build you a set of steel ramps for less money but they will be heavy as hell.
~ JT Burkard ~
AKA Sweaty Mack
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150479
Try Adelman's Truck Parts in Ohio. They part out auto transport trailers.
Good suggestion David. Here is the contact number for Adelman's; Canton, OH 800.643.2001.
www.adelmans.com
Ken
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150493
Yea im already talking to my buddy whose gonna do that for me. My gooseneck had steel ramps and they where only 6 or 7 feet long. and they where insanely heavy. I really don't want to be lugging around those ramps all day. But you gotta do what you gotta do.
Tom
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150535
www.adelmans.com
they've got lots of stuff there all right. I went off-roading, out of route, through the briars, through the brambles, and had to turn around in a field to get a picture of that IH Paystar in W.V. that I thought was so rare that time, then I passed by Adelman's one day and they had a small fleet of Paystars lined up in there.
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150546
Tom
You are going to need a ramp a lot longer then 6-7 feet. Figure if you want to haul cars, trucks, rigs etc you need something at least 14'. Here is a calculator: http://www.discountramps.com/ramp-calculator.htm#div5
Figure long cars and trucks 4x2 are low as well as equipment like larger rigs and equipment into the equation. I put in 180" WB at 8" of ground clearance and. 36" deck height and got 14' min length. Discount ramps offers financing as well. The nice thing sbout a step deck is its versatility. You don't want to have to pass on loads because your ramps are too small and you can't load it.
Penny saved pound foolish.
~ JT Burkard ~
AKA Sweaty Mack
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150548
you wont be able to pick up the home built steel ramps, I have a set for a car trailer here that are wayyy to heavy but the longer ramps seemed like a great idea at the time, I second the Discount Ramps financing idea I have had to do things like that before and you will be a lot better off in the long run for sure I would go with the 4 piece 16' set with the pedestals for the center theyt double as load levelers and if you are loading a tractor or anything short or good clearance you can just use two.
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150557
http://www.discountramps.com/step-deck-load-leveler-ramps.htm
look at the 18" wide 2 bunk kit 4th down it is the one I would be after you get your ramps and load levelers all in one.
https://www.bigmacktrucks.com/topic/28770-drop-deck-ramps/#findComment-150560
